mikefernandez
- Mar 6, 2014
- 3
- 0
- 1998
- 5.9L Magnum
Well, I just bought my first truck and I decided to go with a 1998 Ram 2500 4x4. It has the 5.9L Magnum engine, which at 50K miles was replaced because the piston rotated sideways and cracked the block. It is at 180,*** right now. The transmission is a Jasper and was replaced not too long ago and is still under warranty. I believe the paintjob is Maaco because of how the clear coat is flaking off so easily. The rear bumper is missing, the tailgate is hard to open and has rust holes on the top. The steering wheel sits about 5 degrees counterclockwise of where it should be at center, and when the steering wheel is turned i feel and hear it grind a little, im guessing it is the intermediate shaft. The side view mirrors are cracked, the tail light lenses are cracked, one headlight is oxidized heavily. The dash is cracked in two spots, the shifter handle plastic is cracked and will slide off if pulled. The passenger side window will not move if using the driver side controls. The driver side door lock won't move with the electric door locks. There are a few small dents on the body and a baseball size dent in the rounded part of the body next to the bottom of the tailgate and its rusting through. These are the issues I am aware of.
I took a look at some parts and whatnot how to make this truck perform and look great. I found a parts truck and got a bumper, tail light covers, and a tailgate with much less damage. I plan on repairing the dents with filler, taking off the clear-coat that's peeling, sanding the edges of the clear-coat to smooth it, and then plasti-dipping the truck. I have 3 gallons of black, 2 gallons of orange, and two gallons of glossifier. It will be black with two orange stripes. For the steering I am going to try the pre-load adjustment, if that doesn't help, then I will do the center alignment. If that still doesn't work I guess I will buy the Borgeson intermediate shaft. I can trace the electrical parts and figure out whats wrong fairly easily.
I never did body work or steering work so any and all suggestions are what I'm looking for. Thanks.
