The sports are tricky. I tried quite a few different brands before I found some that work right. XKGlow worked great but the bulbs were anodized red and when I turned on the headlights they appeared pink so I switched to a cheap ebay set which didn't even work.
Currently I run Putco Cree's, my only issue is my high beam bulbs don't turn on, and the lower section (high beam) on my low beams come on when I turn the fog lights on. Doesn't really matter as the headlights don't get any brighter, it just illuminates the lower section of the housings which act more like a fog light.
I've thought about messing with the wiring to get the high beams to work correctly, but I have a set of non sport headlights I'm going to build and haven't messed with it since buying all my stuff.
