ChrisJones
- Jan 24, 2016
- 41
- 28
- South Carolina
- 1999 Dodge Ram 1500 Sport
- 5.9
Any ideas on how to fix this? My pedal just about rest on the floor with my mats in. Gif of Problem
Zip ties work fine if you're only needing one or two, otherwise yeah,vacuum hose. LolLike dodge dude94 said, spacers. In between the part of wire from the small white plastic ring going towards the end of the throttle cable wire, you need to add space so the pedal is firmer.
I found that zipties didn't work very well on their own. Instead, try getting some small vacuum hose line (about the size of break lines), splitting it down the middle with a knife, then slipping it over the wire and zip tying it in place at the top, bottom, and middle.
I'll take pictures of mine if you'd like !
