Joshinparadise
- Feb 6, 2017
- 10
- 1
- 1997
- Cummins 5.9
Hello,
I am brand new to the forums, thank you so much for taking the time to read this. I've been pouring over these forums trying to find answers and there seems to be lots of info, but nothing definitively pointing me in a direction and I could use some help from you fine folks who know more than me.
I just bought a 1997 Ram 2500 5.9 cummins 4x4, manual, long bed, quad cab (or whatever they call it for the extra crew seats in back). It has 130k miles on it and its in pretty amazing condition (no rust!), however, it definitely needs new suspension.
My goal for this truck is partially to have it as a daily driver for work when I don't have to entertain clients in my car, but mostly, this is my bug-out vehicle for my family should we have a SHTF situation (whatever that may be) here in SoCal. My wish is to make the truck as reliable, robust and emp proof as possible and extend it's range without refueling, without getting to far away from mostly-stock.
The immediate need is to replace the suspension and I'm looking for thoughts and advice on what i'm being told by the local ORW shop experts as to what equipment to use in my upgrading and what's really necessary. Here's what they're suggesting:
Carli Ram leveling kit - Multi rate coil springs, bilstein 5100 shocks (front/rear) w/adjustable SS sway bar end links. (What is the benefit to leveling? I'm lost on this!)
Fabtech Adjustable Traction bar (FTS93002)
Synergy Heavy Duty Steering kit - There's quite a bit of bump/grind/play/noise in the front end of the truck.
Fox 2.0 performance series Steering stabilizer
New sway bar end links and bushings
I just installed a stainless steel 4" exhaust from the turbo back, eliminating the cat. converter, which I can do because pre 1998 doesnt needs smog check here in Ca.(yay!) I'm also planning on flushing all coolant, brake and transmission fluids since I don't have any maintenance records.
Some other things i'm hoping to do here in the near future:
1. Replace headlights/fog lights (they're completely frosted over at this point)
2. New lift pump (I hear that these fail all the time, but I want to put in another stock (or similar) mechanical one instead of one of the high flow electric ones)
3. Install an auxiliary fuel tank in the bed of the truck 50gallons - been looking at titan fuel tanks.
4. K&N air filter kit - not just the filter, but the whole kit that they make
5. ATS high flow air intake - on the fence about this one.
6. New carpet - its the only thing that really needed to be replaced in the cab, but considering putting down dynamat or something similar to reduce engine/road noise in the cab when I redo the carpet.
7. Over cab utility rack
And a partridge in a pear treeeeeeeeee. So... I know I just threw a wall of text at you fine folks, but if there's anything i've mentioned here that you have any thoughts on, I welcome them!
Thank you in advance for your kind consideration of my plea for assistance from those who know so much more than me.
JoshInParadise
JoshInParadise
