I realize they aren't manual hubs. But even in 2wd the front axles are turning all the time. Are the locking mechanisms in the hubs themselves or in the front differential? I was hoping to wait on changing the u-joints until a more convenient time. But if they are always engaged / turning I can't wait to repair or the yokes will be ruined. Thats my dilemma.
Both front axles, the front diff and the front drive shaft turn all the time. It's the transfer case which engages the front driveshaft when you switch to 2wd. As others said, if your front u-joint is toast, change it now.
There are no factory front LSDs, and an LSD in the front axle is highly undesirable since it would try to keep both front wheels turning the same speed, even in 2wd. Snow and ice driving would be dangerous.
