Precisionauto
- Apr 15, 2016
- 1
- 0
- 2001
- 5.9
I know its a long read but PLEASE!
Hopping i could get a little help from you guys as to what my issue might be with the truck I just bought.
Heres a little history, lady i bought it from was driving home from work one day and as she was leaving a light it was stuck in second. Now thats all I could get from her and thats all I know about how it happened. I know, tons of info....
Here is what I do know, which isn't much either but hopefully enough to get a general Idea...
Removed the Trans Relay, it will stay in 3rd gear when in drive but I can use the shifter to shift to second, then back to drive for 3rd.
I replaced the relay and figured i mess with the shifter, if i wiggle the hell out of the shifter the trans will SOMETIMES eventually find "D" and shift from 1st-3rd and then into OD. Its very rare that I can make this happen. Typically if I'm in between N and D.
I figured that it might be the shift linkage sooooo I made adjusted everything and nothing... I even disconnected the shift linkage entirely from the transmission, put the E break on, and put it in drive by hand... Still stuck in second... 1st dose not work either unless I just magically hit the sweet spot like explained above.
I have not had a chance to hook it up to a GOOD diag tool, although I do not have ANY codes for the trans or engine for that matter unless I of course remove the relay... I'm at a loss thus far, thinking its either the govener solenoid or the whole solenoid pack but would really like to know for sure before i replace them.
ANY help, or Ideas would be highly appreciated. Thanks, Newb
RE: AHH Alomst forgot!
2001 Dodge RAM 1500 (quad cab)
5.9 V8 GAS, AUTO, NOT 4x4
