NV3500 conversion
cdstl
Hey guys I'm putting together parts to convert a '96 SC SWB auto to a manual transmission truck. I have a couple of questions.
Is the pushrod for the brake Master cylinder the same length on auto trans pedals and manual trans pedals?
Is the drive shaft the same length?
Thanks
dapepper9
Iowa/Nebraska Border
5.9L V8
driveshaft "should" be the same length. I believe it is but as for a 100% guarantee, that I cannot provide
Chris828
Chicago
5.2L Magnum
I doubt the driveshaft will be the same. Had a hard time finding a replacement for my MT as it was a different length than the auto so the manual driveshaft needs to be longer than the auto. I think it's because the manual trans is smaller than the auto which. If you call a driveline shop they might be able to tell you for sure.
1Popeye
