waylin89
- Apr 20, 2016
- 2
- 0
- 1998
- cummins 5.9
hey guys. on my 98 cummins I rebuilt the tranny, I had lost reverse then the forward gears followed. so I got it taken apart and bought a rebuilding kit for it. I got the transmission put back in the truck today. the truck will only go in reverse when I put it in the reverse gear on the shifter. I tried putting it in 1st all the way to 5th and the truck doesn't move. the t-case is locked in 4x4. I moved the shifter from 2 high to 4 lo. the only time it kicks out of four wheel drive is in the neutral spot on the t-case gear shifter. I cant find anything on the web that has a discussion about the problem I am facing. any help would be greatly appreciated.
