off-road edition differences
LaurenMagnum360
Illinois
360 V8
so I was curious about the front suspension on the off-road edition 1500s.
how does it get it's 2.5 inch lift WITHOUT shifting the axle to the drivers side?
does the off-road edition get a special track bar? or a factory drop bracket?
anyone know?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
It's a 2in lift front and rear if I remember correctly. 2.5 is the tipping point for a ***** track bar.
LaurenMagnum360
LaurenMagnum360
Illinois
360 V8
so I should get an adjustable track bar before putting my leveling kit on then
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
lol I use it quite often, mainly because lately I've been working with things that are *****'d. LOL
Are you going with a 2.5 inch kit?
LaurenMagnum360
LaurenMagnum360
Illinois
360 V8
I have the complete rough country 2.5 leveling kit. front and rear blocks, and the extended shocks. just need a track bar.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
You could run it and see what happens. These trucks are so weird in that some can run a 2.5 fine, others have the axle pull.
LaurenMagnum360
LaurenMagnum360
Illinois
360 V8
I would, except for I'm moving next month. So I'll be pulling a 16 foot trailer from Rhode Island to Illinois. so idon't wanna take any unnecessary chances
Merc225hp
NA
truck
gas
Wait wait you don't need an adjustable track bar until you get to 3" lift or more. Stock one is fine.
Op your truck an ORE?
Brakelate
South/Central Utah
****** Up Beyond All Repair.
military term coined in Vietnam I think...
The phrase came in long before that... made popular in the WWII classic "Saving Private Ryan" and their depiction of the Invasion on the Beaches of Normandy.
As far as the track bar goes, don't get too crazy with the lift, if you want a hassle free towing experience. Especially when times are tough and funds are short.
My two cents.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
My two cents.
Ah, I couldn't remember if it was WWII or Vietnam. Knew it was one of those two. Thanks for clarifying. :D
Merc225hp
NA
truck
gas
^^^ Ok thank you for answering that.
Stock bar is fine with just 2.5 lift, factory gives you up to 1/8"-1/4" allowance. You might/should get an alignment done after your install, steering wheel will be off center as well. Did you get new rear u-bolts? You will need some. Stock shocks will also work with this lift size as well.
As for what's diff in the ORD trucks
1.75-2" taller over reg 1500's
Factory 4.10 gears
Rear LSD
Extra webbing on the front diff's pumpkin
Different front springs
17" ORD wheel
Tow hooks
Special ORD badging
LaurenMagnum360
LaurenMagnum360
Illinois
360 V8
Factory 4.10 gears
Rear LSD
17" ORD wheel
Tow hooks
Special ORD badging
I have the front and rear blocks, the u bolts for the rear, and 4 r/c n2.0 shocks for 2-4" lifts
Merc225hp
NA
truck
gas
I am more of a rear add a leaf person. Stacking rear blocks is frowned upon but people do do it and company's do sell them, just keep an eye on the rear u-bolt tq once a week for a bit. A tall one piece block is better over stacked blocks, just have to watch for axle wrap.
LaurenMagnum360
LaurenMagnum360
Illinois
360 V8
if it wasn't for the fact my truck is only a daily driver, i would use either a single block, or the add a leaf. i only want to get a bit mroe clearance to get some 33's or 35's on the truck to help out in the snow.
Johnn123
Ontario
Bigger tires are actually WORSE in the snow. Wider you go more slipping you're gonna do. Skinny tires work much better in the snow. I wouldnt do 35`s on a half ton they eat through to many front end parts to be worth the. Sounds to me like you should do an Add a leaf, not a block if you`re gonna be towing. My 2 cents.
1Popeye
