Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
oil pressure drops at stops
This is a discussion on oil pressure drops at stops within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
As the title says I drive for a while then when coming to a stop my oil pressure dips to ...
Reply
Old 02-18-2014, 02:41 PM   #1 (permalink)
Ram Year: 1998
Engine: 318
Default oil pressure drops at stops
As the title says I drive for a while then when coming to a stop my oil pressure dips to nothing then goes back up to normal..when at a stop light it seems to do it a couple times but it stays normal when driving
Anyone know what's up with that or had a similar problem..
Sponsored Ad
Register to remove this ad.
lovemaram is offline   Reply With Quote
Old 02-19-2014, 06:27 AM   #2 (permalink)
jf5.9's Avatar
Ram Year: 1998
Engine: 5.9L
Default
I had this problem back when I still had my 2000 Dakota 4x4 with the 3.9L Magnum.
Ended up being sludge in the pan that was clogging up the pick up tube for the oil pump. I would highly suggest at this point dropping the pan and inspecting what it looks like. If it is a sludge problem now is the perfect time to look into a high volume oil pump.
Finch
__________________
1998 Ram 1500 4 x 4 5.9L Magnum, Rhino Lined Wheel wells and Rockers, Line-x Bed, Smoked Head lights, Tail lights and third brake light, Hughes Plenum Repair, and full tune up. Spectre CAI running on 127k mi - the tug for the jeep to places
jf5.9 is offline   Reply With Quote
Old 02-19-2014, 05:48 PM   #3 (permalink)
Ram Year: 1998
Engine: 318
Default
Thanks I will check that ..it blew an intake last year and was replaced...and it blew it again not too long ago cause the people that did it didn't line the gas get up good leaving a small leak..
Old 02-19-2014, 06:00 PM   #4 (permalink)
98hemi-ram's Avatar
Ram Year: 1998 ram 1500
Engine: 5.7 Hemi
Default
My 99 dakota dakota with a 5.2 did this once to. Turned out she burned alot of oil and was just dangerously low. About half as much as (or less) than what should be in there and didnt even show up on the dipstick. Once I filled it back up never happened again.
This was just after I got the truck and learned to keep a much closer eye on the oil after that lol.
Sent from my SM-T210R using Tapatalk
__________________
98 Ram 1500 RCSB 2wd
5.7 Hemi swapped, Lowered, and some shiny new paint!!
Best 1/4 mile - 14.63 @ 93.20mph
98hemi-ram is offline   Reply With Quote
Old 02-19-2014, 06:09 PM   #5 (permalink)
Ocelot's Avatar
Ram Year: 2011
Engine: 4.7
Default
Same as Finch, but with a Jeep Cherokee we used to have. Sludge in the oil pan. I dropped the pan and the screen was covered. I was gonna clean it at the time, but since I had the pan off anyway, I replaced the pump. Worked great after that. It was probably at around 120k miles.
Ray
__________________
2011 Ram 1500 SLT Quad
Ocelot is offline   Reply With Quote
Old 02-20-2014, 12:58 AM   #6 (permalink)
Ram Year: 1998
Engine: 318
Default
I have the 318 4x4. How hard is the oil pump to change out..
Reply
Tags
low oil pressure, oil pressure, oil pump, oil sludge
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Battery guage drops rb5739 General Discussions 4 01-10-2014 01:57 AM
Battery guage drops rb5739 General Discussions 3 01-08-2014 08:40 PM
2006 trans skipping a gear and drops on face brianj12 5.9 Common Rail 0 10-15-2013 06:03 PM
Hum when hemi drops to 4cyl cajun87 Engine & Performance 15 07-20-2013 08:38 PM
Hemi reads 0 oil pressure at start up. Shut off and restart and full pressure. 2k2wranglerx Engine & Performance 1 10-25-2012 02:24 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
