870master
- May 20, 2016
- 10
- 0
- 1997
- 5.9 v8 360
got a p0340 on my 1997 ram 1500 5.9 v8 auto. looked it up and said it was camshaft pos sesor... but i guess i dont have one of them.. did some diggin around and found pick up coil in the distributor. so i swapped that out today, started it up, was running smooth, revved it up, no probems, let it run a good while and went to drive it around to make sure it was fine. well.........
i put it in gear and let off the brake, i go no where... give it gas and im still in the same spot. move the shifter up and down, feels like its going into gears, back into first and it crept but got moving. seemed to stutter some but it worked out of it, was driving around the block and was getting some back fire. first just one... then three quickly, also felt like it wanted to die.. so i coasted back to my parking spot and here we are!
cap is tight, plugs are where the are supposed to be, truck has not been sitting long only a couple days, no CEL light on.
thoughts?
thoughts?
