Parking and dash lights are staying on
This is for the gas truck in my signature. I just picked it up recently and found that the parking lights and dash lights stay on. The truck came with the tow package so it has the plug for the trailer, but the receiver hitch and trailer plug are missing. The plug from the harness is clean.
ALL of the other electrical works perfectly. Except for the dome when you open the door. The thumbwheel will turn the dome on.
I cleaned all of the grounds on the firewall.
I cleaned the ground that has about 9 wires on it below the battery.
I couldn't find a ground in the rear for the trailer or rear light assembly, if there even is one.
I dropped the spare and the rear harness looks good. It wasn't rubbed by the tire.
I checked all of the parking bulb sockets and they're all clean.
I even threw in another CTM to see what would happen. Nothing changed.
I got another headlight switch at the JY but left it at home and won't be able to put it in this time around. The Headlight switch plug looks good. The lights go off with the switch removed.
This is the only ground that is missing. It is on the DS fender above the headlight. Any idea where it goes?
Thanks
Thanks
