Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
Pinion bearing/flange interference
This is a discussion on Pinion bearing/flange interference within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
Alright so I finally narrowed down my noise (whining/howling at 15+mph in any conditions) to the rear end. Pulled the ...
Reply
Old 03-20-2017, 06:04 PM   #1 (permalink)
BlackMagnum2000's Avatar
Ram Year: 2000
Engine: 5.9 Magnum
Default Pinion bearing/flange interference
Alright so I finally narrowed down my noise (whining/howling at 15+mph in any conditions) to the rear end. Pulled the cover to find a TON of metal.
Start tearing it apart.
Pattern is fine. Gears are fine. Races fine. Bearing rollers are fine.
I finally found a spot on the outer pinion bearing where there was a small groove. On the pinion flange, there are small grooves and a lip on the inner edge. Do you guys think this is my problem? And also, what would cause this? I understand the damaged flange could damage the bearing, but how would those grooves develop on the flange in the first place?
Sponsored Ad
Register to remove this ad.
__________________
2000 Ram 1500 SLT 4X4 QCSB
Lightly modded 5.9. 4.88s
7 inch Skyjacker lift. 37" Toyo M/Ts
Pretty much new everything
BlackMagnum2000 is offline   Reply With Quote
Old 03-20-2017, 06:08 PM   #2 (permalink)
jbmobbs's Avatar
Ram Year: 1996
Engine: 5.9 360
Send a message via AIM to jbmobbs
Default
From where the bearing is sitting still and the pinion is moving.
__________________
96 ram 1500 ex-cab long bed 4x4. 5.9 nv4500 5 speed fully loaded
97 ram 1500 regular cab short bed 2wd. 3.9 42rh automatic basic
jbmobbs is offline   Reply With Quote
Old 03-20-2017, 06:51 PM   #3 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
I've seen similar things happen when people don't properly set the preload on the pinion when doing repair work, but not outside of that. To me it would appear that something cause that bearing to lock up either fully or partially. Looking at the picture the inside of the bearing and the outside of the pinion look chewed up too.
I'd say most certainly that bearing has hit some resistance and got screwed by the much harder pinion. I cant see in the picture all too well, but it looks like there is rust on parts of the pinion that are exposed only to the inside of the differential.
The fluid looks like it is filled with water. Sure some of the foaming will come from agitation of the differential, but thats just too far to be anything but water. If I had to guess, water go into the differential, either cause rust that broke free and jammed the bearing, or prevented the oil from properly lubricating the bearing and that caused it to jam.
That looks like a lot of water, have you submerged the axle in the past year?
You should be fine just to replace the bearing, and put everything back together, the pinion doesn't look damaged enough to warrant replacement. Personally, i'd replace the axle seals as well, you might have to buy the tools to do it if you cant make your own, but they aren't too expensive and its much cheaper than paying a shop.
__________________
I fixed it until it broke.
Old 03-20-2017, 07:03 PM   #4 (permalink)
Ram Year: 2000
Engine: 5.9 Magnum
Default
Preload was set within spec. No way for there to have been water in it, fluid was changed weeks ago and the truck hasn't even been out in rain since. Let alone off road/submerged in water.
Possibly just the picture, but the pinion was not chewed up at all. No rust on it either. Possibly just bad lighting in the pictures.
Also, axle seals are not leaking. And as stated, there wasn't water in it. The picture of the fluid was a screenshot from a video from snapchat lol, so take what you see with a grain of salt. It was just to show how much metal was in it. All very fine metal, by the way. No big chunks.
__________________
Old 03-20-2017, 07:09 PM   #5 (permalink)
Ram Year: 2000
Engine: 5.9 Magnum
Default
Looking back at the pictures, in the back back ground of one picture is the flange that is dirty if that's what you were seeing that looked like rust.
The pinion might look bad in the picture but that's just from the angle I suppose
After looking at it in better light, there are some slight marks on the bearing rollers. Not much, but I'm replacing them regardless. Figure it's probably from the metal in it, as all the bearings look the same. So I'm replacing all four bearings and races, as well as taking the flange in to machine it tomorrow. Hopefully this will take care of my issue
__________________
Old 03-22-2017, 12:32 AM   #6 (permalink)
Engine: Magnum 360
Default
I take it back. The pinion looks clean. If you say there wasn't water in it, i'll take your word for it. Still, thats a weird color consistency for gear oil. Was there friction additive in it?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How long on a bad pinion bearing. CC12RamLove 4th Gen DIY 3 11-16-2016 03:13 PM
Rear pinion bearing went out....speedo doesn't work now?? IQRaceworks General Discussions 7 10-10-2016 08:57 PM
Inner Pinion Bearing Race MarkV Engine & Performance 3 11-27-2015 07:17 PM
Pinion bearing or axle shaft bearing? Bigboytoys General Discussions 16 03-21-2015 08:55 PM
Pinion bearing sizes... rebel89820 Tech Info 4 06-03-2014 01:26 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
