Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
Rattling noise in 2 wheel
This is a discussion on Rattling noise in 2 wheel within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
Hello all. My mechanical abilities are limited to say the least, so please be patient. My 2002 slt 4x4 is ...
Reply
Old 02-17-2014, 10:13 AM   #1 (permalink)
Ram Year: 2002
Engine: V8 5.7
Default Rattling noise in 2 wheel
Hello all.
My 2002 slt 4x4 is based in Belize and 'Gringo's' in Belize usually get "jacked' when taking in a vehicle to a mechanic, so I would like to eliminate a few things that could be the issue that I could do myself before taking it into a mechanic.
OK, Symtoms!
When in 2 wheel drive there is a loud rattling noise that sounds as if it's coming from under the drivers seat under the vehicle.
When I engage 4 wheel drive the noise disappears.
Others have told me it could be the 'Transfer Box?'.
Could I do regular maintenance checks on things like fluid levels in transmission or differential or transfer box ( if it does have fluid)
Thanks in advance for any help and advise
Sponsored Ad
Register to remove this ad.
Mcagun is offline   Reply With Quote
Old 02-17-2014, 10:17 AM   #2 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
Welcome to RF.
What you need to do first off is set the parking brake, put the transmission in neutral, and slide up under the truck and try and make the front driveshaft move. If it moves laterally, (which it shouldn't) you have a u-joint problem, which is what I am leaning toward.
You should also check to make sure nothing is close to the driveshaft or any other moving/vibrating parts. And when I say check, I mean literally LOOK at it as well as verify with your hand that nothing is touching.
Hope this is a starting point and best of luck!
A member by the name of Merc225hp should be on sometime today and can help you much more than I can.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Reply
Tags
drive shaft noise, rattling, u joints, vibrations
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Rattling noise from valve cover Saabonthis Engine & Performance 18 09-26-2013 08:21 PM
Rattling noise after start up? lone12star Tech Info 2 07-03-2013 06:51 AM
Rattling noise after installing Bullydog regular tune josh24 Engine & Performance 4 06-15-2013 04:57 PM
Rattling noise? sandstorm General Discussions 3 03-08-2013 01:39 AM
susupension noise / clunk + wheel bearing noise? sdamike General Discussions 7 02-26-2013 04:20 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
