I have a 98 ram half ton with rear abs. The abs module is out and i would like to get rid of abs. The speedometer signal runs through abs module. Has anyone got rid of abs and been able to make speedo work. Thanks
I hate abs in the snow. Countless times I pressed my brakes and hear the grinding noise as it cut braking power when I need it!! So I removed it and ran the brakes straight. Now if you say I need to have the module plugged in, does it have a computer that has an input and output for my speedo or does it simply plug in for the reading and give an output the same as input? I've ran the truck for a year without the speedo or abs module. Been using GPs speed and I've learned my rpm speed. I believe OD is disabled since the speedo has no output
Damn. So if I hooked it back up even with the new sensor in rear axle, would it work with both front wheel bearings not having sensors anymore? Or is that only for abs functions.
Not sure what you were seeing, but the Gen 2s had only 4wabs or rwabs. There are no front wheel abs only vehicles in Gen 2 as far as I know.
No, you won't have an abs light I don't believe as long as you plug in all the sensors that that ABS module is expecting.
If you have abs sensors on the front two wheels, then you had 4 wheel abs. In that case, your abs module needs to see input from all four sensors, otherwise it will throw the abs light.
You should be able to bypass the sensor on the brake line side without problem.
If you had 4 wheel abs before, and no longer have the front wheel sensors, you need to get a 2wabs module in order to not see the abs light.
No matter what the abs light says, as long as the rear diff sensor is plugged in to the abs module, and the module is plugged in, there will be spedometer readings.
If you still have the schematic, where does this red/ black wired plug go?
