Cooper481
- Oct 13, 2015
- 16
- 2
- 2002
- 5.9 Magnum
I have an 02 2500 4x4 with the 360. I've noticed ever since I've had it, that when your backing up slow and are turning left or right while doing so, that there is kind of a popping noise coming from the rear end.... somewhere. I've had my dad back there listening and looking while backing up and you can hear and feel it from both sides, and if you watch the wheel closely, you can see it move with the noise, if you get what I'm saying lol. It never does is if your backing up in a straight line, and it doesn't seem to do it as bad going forward. I've checked the axle shafts bolts to make sure they're tight. I've checked the axle hub nuts to make sure they're tight. I guess I'm to the point of pulling the diff cover off and checking in there, just want to see of anyone else has any opinions before I do. Thanks
