Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
sloppy steering
This is a discussion on sloppy steering within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
As the title states, I've got really sloppy steering in my 96 3/4 ton. The play is for sure in ...
Reply
Old 12-27-2016, 01:04 AM   #1 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default sloppy steering
As the title states, I've got really sloppy steering in my 96 3/4 ton. The play is for sure in the steering box which was replaced last spring. I have tried doing the adjustment that there is a write up for in the DIY section with no luck. Anything I could stop tighten it up? Thanks.
Sponsored Ad
Register to remove this ad.
12vcummins59 is offline   Reply With Quote
Old 12-27-2016, 11:05 AM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
My first suggestion is take it in to a reliable honest alignment shop. They'll verify whether or not something else is causing you an issue that you may not have checked. Also reman steering boxes really aren't that great usually. Misty would recommend a Redhead rebuilt box or a borgeson box. Lastly, there's a bushing that you can sparkly replace in the steering column that kills play in the shaft
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 12-27-2016, 11:30 AM   #3 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default
Thank-you will look into that
Old 12-30-2016, 08:53 PM   #4 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
I'm not necessarily going to make a recommendation, but I'll play the black sheep role nonetheless. My truck had the usual 2nd gen steering slop and I opted to buy and install one of those "steering stabilizers." I will say that it tightened up the steering considerably. I have had my steering box looked at prior to this and it is pretty much used up to the point where it can't be adjusted and it does leak a little. Also, my truck has always pulled a bit to the right. I purchased the stabilizer because at the time (and my then ****ty job) it was the cheapest route to go to "fix" the problem.
So, with a good steering box and an alignment, I'm not sure how effective a stabilizer would be. I think that it'll either help or do nothing at all. I'd say fix/replace everything involved with steering and get a good alignment first. Afterwards if you're still not happy, consider a stabilizer. If you're STILL not happy, consider that our trucks use a pitman arm setup rather than a much slicker but more expensive rack and pinion setup. In other words, you'll have to deal with it, LOL.
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
American Racing Nitro, K&N open element, modified 50mm, 2.25" y-pipe, Magnaflow cat, Cherry Bomb Extreme, tuned by Flyin' Ryan, Hughes plenum repair, steering stabilizer, 4x4 Posi-Lok
Yeret is online now   Reply With Quote
Old 12-30-2016, 09:30 PM   #5 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default
A steering stabilizer is actually the first thing I put on the truck after getting it and it helped a little bit, hopefully gonna get it aligned with new tires this weekend. Hopefully that helps
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sloppy Steering Adjustment Bigtman07 2nd Gen DIY 74 11-28-2016 11:39 AM
Sloppy Steering Wheel Play jacobsmudder General Discussions 3 10-15-2016 08:31 PM
Replacement steering gear and steering column bushing Tryin General Discussion 12 11-16-2015 11:07 AM
Leaking gear box, sloppy steering mok4200 Tech Info 5 03-29-2015 04:55 AM
Sloppy handling? Jpeyatt General Discussions 7 10-07-2013 11:43 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
