Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
stalling in reverse
This is a discussion on stalling in reverse within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
morning guys, so my truck has been stalling in reverse and I'm not really too sure.ohanwts causing it. so I'll ...
Like Tree3Likes
  • 1 Post By dodge dude94
  • 2 Post By Merc225hp
Reply
Old 02-18-2014, 07:31 AM   #1 (permalink)
LaurenMagnum360's Avatar
Ram Year: 2001
Engine: 360 V8
Default stalling in reverse
morning guys, so my truck has been stalling in reverse and I'm not really too sure.ohanwts causing it. so I'll break it down to when it happens, and when it doesn't.
first thing in the morning stalls if put into reverse after starting. but drive works fine.
same if the truck has been turned off for a bit.
but if I start it and put it into neutral for a few seconds it's fine then.
if I start the truck and let it warm up, reverse will not work at all until driven at least a mile. I started my truck this morning and let it warm up. when I got down to the end of my street someone was blocking it, so I put it in reverse and it stalled. I had to hold the throttle to get it started, almost like the engine was flooded. I eventually got it backed up enough after a few tries and full throttle to barely keep the engine running.
but after I got to work, reverse worked fine.
I've already replaced the iac, and the transmission shifts perfectly in all forward gears. it almost feels like it's either flooding, or losing spark when it stalls. it's not like it locks up or anything.
I'm stumped
Sponsored Ad
Register to remove this ad.
LaurenMagnum360 is offline   Reply With Quote
Old 02-18-2014, 12:25 PM   #2 (permalink)
Ram Year: truck
Engine: gas
Default
Check the motor over for any vacuum leaks, there are lines the run down the tranny to the top of the xcase they get old and brittle and will leak, next would be to swap out the CKPS. When you replaced the IAC did you clean out the port on the TB where it goes? Did you reset the pcm? Last time a full tune-up was done?
Merc225hp is offline   Reply With Quote
Old 02-18-2014, 05:55 PM   #3 (permalink)
Ram Year: 2001
Engine: 360 V8
Default
i'll take a look at the vacuum lines this weekend, along with hopefully getting around to doing the crank sensor.
i did not clean the iac port, as it was spotless. the iac had just failed and locked up.
i did not reset the pcm, nor do i know how to do so.
idk when the last tuneup was. i just put in some new autolite plugs last week, and i'm waiting for this weekend to try and get the distributor cap off. probably will replace the cam sensor while i'm in there.
Old 02-18-2014, 05:59 PM   #4 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
You can reset the PCM by removing the positive battery cable and turning the headlight switch on for approximately 15 minutes. Turn it off, reconnect the cable, take it for a drive.
LaurenMagnum360 likes this.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 02-19-2014, 06:59 PM   #5 (permalink)
Ram Year: 2001
Engine: 360 V8
Default
i believe i have found my problem.
i believe my issue is the Map sensor. and i have a hypothesis as to why.
i plugged my code reader in, and ran live data.
at idle, i'm drawing 10.2 in/hg of vacuum.... and i have no vacuum leaks.
my hypothesis is, that since the ECU thinks it is getting 10 in/hg of vacuum, it thinks the engine is under load and is dumping extra fuel into the motor. When i stick it in reverse, the rpms drop more than drive, and the IAC has to compensate even more, resulting in the vacuum level dropping and the ecu compensating for more fuel.
but, the engine is dumping more fuel, without the T/B opening, meaning it will flood out. which would answer the reason i need to hold the throttle open to get it to start again.
i just ordered a new map sensor, and i'm hoping it fixes this issue.
btw, i tested my theory by letting my engine cool completly and I unplugged the map sensor. i started the truck, and it popped the CEL for the MAP not being plugged in.... put it in reverse.... viola... no stalling -_-
now we'll know for sure in a few days when i get my new sensor.
Old 02-19-2014, 07:17 PM   #6 (permalink)
Ram Year: truck
Engine: gas
Default
If you look under the map there is a little rubber hose with a 90 in it that goes to the TB, make sure it's still in one piece and not split all to heck.
Good find by the way
Old 02-19-2014, 07:22 PM   #7 (permalink)
Ram Year: 2001
Engine: 360 V8
Default
i'll take a look at that after work tomorrow when it's still a bit light out.
Old 02-19-2014, 07:48 PM   #8 (permalink)
Engine: 5.9 Magnum
Default
^This.
Check that hose before you replace the MAP sensor.
__________________
Reply
Tags
stalling problems, stalls in reverse, transmission issues, truck stalls out
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stalling in the wet, need help OfficerJoseph Tech Info 15 02-19-2014 08:05 PM
stalling gatorpsp Engine & Performance 19 07-22-2013 08:30 PM
Can anyone help with stalling?!? Nickdb87 Engine & Performance 4 01-31-2013 05:48 PM
Stalling out BlackedOutHemi Engine & Performance 25 07-09-2011 10:39 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
