Thanks for the reply. I'll order it.
Also, I just pulled the intake bolts. Broke the front 2...#@%$. Does the distributor just come off with the keg or do I need to pull that first? Confused by the few write-ups I've found.
Never mind. Guess it stays put.
Yes. Looks like the gasket failed there at both sides causing a coolant leak and corroding the bolts. Looks like I'll get the right side out in time but the left is in bad shape.
Nothing on pan gasket, nothing on manifold to head gaskets, 1/4" bead on each corner of the front and rear block gaskets
Heat the corner of the head with a torch and then unwind the bolt. Get the head red hot first. Practice on the right one first.
"Talk is cheap. Whiskey costs money."
