I have a 1996 ram 1500 with the 5.9 in it. I bought the truck at 140k miles and so far i have had excellent luck with it just changing the oil regularly. so far ive only replaced the brake pads and tires once. Now that im at 195k miles there is some real issues creeping up. First off the rear main seal is leaking. Every oil change they are sure to remind me. The next few problems are that the power steering pump is leaking fluid and that the motor has a tick at between 1500 - 2100 rpm when accelerating and before its warmed up. Ive done some reading on here and google and it most likely sounds like its the lifters, but i am worried it could be rod knock. Is there a definite way to tell before doing any real work on the engine? Im thinking since im basically going to be taking apart the top end of the engine that while im at it i should replace quite a few things such as timing chain, water pump, lifters, gaskets, cap and rotor & plug wires but my main worry is that its not the lifters at all and might be rod knock. That would make my tune-up pointless. Any input?
