tranny problems
99ram360
Maine
alright well if you have read my other post about destroying my front, theres more. for those that don't the front end of my truck broke through some ice today while trail riding, it was in quite a bit of water. the truck ran fine once i got it unstuck shifted perfect and everything. i shut it off for a few hours at my moms house, went to leave and now it won't shift out of 1st gear. the temperature outside has dropped bellow freezing now so idk if i got water in there and it froze or what?
what do you guys think, should i dropping the pan and draining all the fluid out and putting all new fluid in, or am i up **** creek? thanks in advance
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I would try to warm it up and dry out, then drain and replace for a start
99ram360
99ram360
Maine
ya i was going to go bring it into the garage this morning but went to go start it....nothing the battery has juice but now the started is toast... so i cant get it to where i can work on it an i just spent 50 bucks on filters and fluid for the tranny and i dont have the money for a starter right now so idk what the hell to do..... thanks for the bump by the way
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
starter may have some water in it too, never know
99ram360
99ram360
Maine
ya i know i wanted to get a space heater underneath it but all i have is the like jet engine one and its stuck outside and its like the coldest day we have had so far its like 14-18 degrees. of course it would have to be today
quietpeen
2021 TRX
Hellcat
wow, what a crappy situation
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I would try a heat lamp first, less chance of fire/explosion
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
You sure about battery I mean starter should not just die with no warning should smell burnt or something.
$miley
99ram360
99ram360
Maine
yup everything else works like radio and all and it has almoost 14 volts when you crank the key
1Popeye
