No hes not quite correct. Any v8 1500 auto from 96+ will work.
96/97 are direct swap
98/99 need the 97 under model of neutral safety
2000+ need the 97 under nss AND governor sensor/solenoid
2wd need to swap the tailshaft off and bolt up the transfer case
2500/3500 trucks used:
46re with 5.9 v8
47re with v10/Cummins
Nv4500 5spd stick with 5.9 v8, v10, and Cummins
Nv5600 with H.O. Cummins
The 46re's can be directly swapped following the yearly rules i posted above. Nv4500 stick can be swapped if from v8 truck, v10/Cummins need to swap bell housing input shaft and input shaft bearing (? On the bearing) to swap.
46re with 5.9 v8
So, yes. I was correct except that a 2wd transmission will work also. Cool.
Nice to see the breakdown and what's required. Apparently any transmission in that year range will work.
just dont want him buying a 47re thinking it will fit lol
