Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
transmission cooler line
This is a discussion on transmission cooler line within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
So guys, i picked up a 2001 Ram 1500 with the 5.9 the other day, and first thing i noticed ...
Like Tree6Likes
Reply
Old 02-07-2014, 09:04 AM   #1 (permalink)
LaurenMagnum360's Avatar
Ram Year: 2001
Engine: 360 V8
Default transmission cooler line
So guys, i picked up a 2001 Ram 1500 with the 5.9 the other day, and first thing i noticed is it has a brand new radiator, but only the external transmission cooler is hooked up. So i went to the dealer and bought the trans cooler hose, and the quick disconnect coupler...
Hose P/n : 4883317ab
connector P/n : 52028625AC
i slipped the connector onto the hose, and now it won't come off.
my question is, does this get crimped like the other side of the hose, or not?
The dealer couldn't answer me, because they had never seen this before. But yet i bought it from them, oem mopar parts.
Thanks
Sponsored Ad
Register to remove this ad.
LaurenMagnum360 is offline   Reply With Quote
Old 02-08-2014, 05:18 PM   #2 (permalink)
Ram Year: truck
Engine: gas
Default
No it does not get crimped like the other end, once its on you need a disconnect tool to remove it from the line.
Merc225hp is offline   Reply With Quote
Old 02-09-2014, 10:52 AM   #3 (permalink)
Ram Year: 2001
Engine: 360 V8
Default
thanks, already have the disconnect tool. next question, the fitting is missing the 'spring' clip thingy that goes inside it. any idea where to get that?
thanks for being the only one to respond to my previous question
Old 02-09-2014, 12:49 PM   #4 (permalink)
Ram Year: truck
Engine: gas
Default
Sorry I am lost a bit on this one, if you have an old one post up a pix if you can.
Old 02-09-2014, 04:34 PM   #5 (permalink)
Ram Year: 1999
Engine: 5.9
Default
Hi guys,
New here, I just picked up a 99 1500 5.9, and trans fuild is leaking from the passenger front, which seems to be the lines from the trans to the trans cooler or rad.
What tool did you get the disconnect the lines? Did you rent it?
luigi38 is offline   Reply With Quote
Old 02-09-2014, 05:18 PM   #6 (permalink)
Ram Year: truck
Engine: gas
Default
Welcome to RF
You can buy the set cheap.
http://www.amazon.com/Lisle-37000-Co...1984165&sr=1-3
Old 02-09-2014, 05:31 PM   #7 (permalink)
Redtruck-VA's Avatar
Ram Year: 2003 & 1989 D250 RWD
Engine: Hemi-5.7, 5.9 12v & 24v diesel
Default
Maybe a picture will help, there really isn't a lot in those connectors.
__________________
Greg 2003 SXT-Hemi SuperCharged, OCP manifold, billet CR 20" wheels, AeroForce gage, AFR, fuel Pressure, 46RH trans, Edge 3000, PPP Track Warrior, Shiftlite, TCI ProShifter, 180 stat, all aluminum radiator, HD Trans Cooler, DTT 4:10, LT's, Magnaflow duals cats, Mcgaughys 3/6 spindle kit, Monroe shocks, Caltracs, Aeon bumps, Roll Pan, shaved Ant, tail gate and cowl. And a 2007 QC manual trans/4wd diesel for a support vehicle.
Redtruck-VA is offline   Reply With Quote
Old 02-12-2014, 10:10 PM   #8 (permalink)
Ram Year: 2001
Engine: 360 V8
Default
i found a clip. i had to buy a complete other connector and steal the clip from it lol. its the 4 prong clip inside the connector that mates with the ridge on the 3/8" transmission line
Old 02-16-2014, 12:49 AM   #9 (permalink)
Ram Year: 2001
Engine: 360 Magnum
Default
Hes referring to the retainer clip. However I would advise not hooking that cooler line up. What probably happened was the truck suffered a catastrophic transmission failure and debris got all inside the cooling system. So the stock cooler was bypassed and am external cooler hooked up in its place.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
quadcab is offline   Reply With Quote
Old 02-16-2014, 12:56 AM   #10 (permalink)
Ram Year: 2001
Engine: 360 Magnum
Default
At least flush it out first.
Reply
Tags
quick disconnect line, trans cooler lines, transmission cooler
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transmission auxillary cooler lines LaurenMagnum360 General Discussion 1 02-07-2014 01:10 PM
radiator to aux cooler line LaurenMagnum360 Engine & Performance 0 02-06-2014 11:33 PM
Transmission cooler Mpls612 Tech Info 0 12-23-2013 01:02 PM
Help! Best cab cover (cooler) for just the cab. pmaru77 Exterior 7 08-24-2013 05:58 PM
Transmission Cooler lowcomet Engine & Performance 7 07-13-2013 12:53 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
