2000ram2500
- Mar 18, 2016
- 1
- 0
- 2000
- 5.9L magnum
hi i have a 2000 ram 2500 with a 5.9l magnum the transmission is giving me some concern. it is slipping when cold and when you shift to drive you cant feel it and when you shift it into reverse it seems OK you fell it go in . when you go from r to d you dont get that bump you feel went you got from d to r also it will once in a while get stuck in 2nd gear when driving. when driving it hard it stays is 2nd and the engine hits the rev limiter unit you let for a few sec.s and then it will shift. it was fine up until the past few months i'm thinking of doing a fluid and filter change and would like to know what else i should do while doing that i saw things about adjusting bands, replacing solenoids and so on i would like to put a shift kit in it also what would you recommend to some one that likes to do his own work or am i going to be wasting time and money and should just it rebuilt by a shop sorry for the long winded post
