Ram4u
- Aug 25, 2015
- 23
- 2
- Dry Fork, Va.
- 2001
- 5.9 Magnum
2001 Ram 1500 4x4 5.9 automatic. Issue has just recently and randomly started coming up although it is happening with more frequency now. Truck will start fine in the mornings or after it has been sitting for a while but, if I try to start it right after its run for some time, it acts like the battery is dead or dying. It will turn over very slowly and start occasionally or like here recently, won't turn over enough to start. Will not start when hooked to jumper cables either when it does this.
Previously when the issue first arose, I had the battery, alternator and starter tested and all passed as fine. Replaced the battery this morning when it did it to me on my way to work when I stopped for gas. Slow/hard turning over and wouldn't crank. Wouldn't take a jump for two different vehicles or a jump box. Called my wife and had her purchase and bring me a new battery. Fired up with the new battery although it still hesitated with a slightly slow turnover at first.
This evening leaving work, truck fired up and turned over great. Stopped less then 5 minutes later at the store and come out to leave and it acts like the battery is weak again with very slow turn over and just barely starting up. Ran slightly rough/lopey right after starting which required me to give it a little gas for a minute to keep it running. Tried to explain as thorough with the description as possible. Anyone have any ideas what I should check that could be causing this?
