Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
Truck Randomly Died While Driving
This is a discussion on Truck Randomly Died While Driving within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
So after 4 years with no major problems in this truck, i was on my way home and out of ...
Reply
Old 12-15-2016, 09:58 PM   #1 (permalink)
Jrock2394's Avatar
Ram Year: 1996
Engine: 5.2 V8
Default Truck Randomly Died While Driving
So after 4 years with no major problems in this truck, i was on my way home and out of nowhere i lost all power. It was like i turned the key completely off. Luckily i was near a parking lot and managed to pull in with no power steering.
Here is the kick, the truck has been running perfect. I didnt even feel a hesitation at all before it quit. Also, it is not throwing any codes at all. Since it was colder than a witches tit, i only managed to check a few things. It has fuel pressure, and it turns over fine, and i unplugged the MAP sensor to see if i can get it into limp mode (no luck), and checked all the fuses. Everything looks fine it just will not start.
I did put gas in it about 10 minutes prior which leads me to believe i could have gotten bad gas. But not sure if that would cause it to completely die without any signs.
Any insight on this would be great. Tomorrow after work Im going to clean the IAC and see if i can see or find anything else out of the ordinary.
Sponsored Ad
Register to remove this ad.
Jrock2394 is offline   Reply With Quote
Old 12-16-2016, 07:07 AM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Iac won't cause it to die while driving as it's not in play. Ohm check the coil for 12-15k ohms between the tower and either pin. If that checks good you might want to look at replacing the crank sensor
__________________
2001 Ram 1500 QCSB, 265/75/16 ProComp MT2s, M1 2bbl, F&B 52x55mm TB, JBA Stainless Shorty Headers, Carven R Series, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 12-16-2016, 09:45 AM   #3 (permalink)
Ram Year: 1998
Engine: Magnum 5.9
Default
Swap your ASD (auto shutdown relay) with you ac compressor relay. I had the same thing happen to me and swaping relays fixed it for me.
Max78 is offline   Reply With Quote
Old 12-16-2016, 02:34 PM   #4 (permalink)
Jrock2394's Avatar
Ram Year: 1996
Engine: 5.2 V8
Default
I'll take a look at that coil when I get home today. Thanks for the heads up on the IAC.
If the ASD was bad wouldn't that cause the fuel pump to not start? I have pressure to the rail right now.
Old 12-16-2016, 03:43 PM   #5 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Yes it would and starter wouldn't engage
__________________
Old 12-16-2016, 03:44 PM   #6 (permalink)
Ram Year: 2001 1500 Sport with 3/4 ton spring pack
Engine: Magnum 318
Default
That is correct, the IAC feeds the fuel pump as well.
Old 12-18-2016, 08:13 PM   #7 (permalink)
Meatball12's Avatar
Ram Year: 1999
Engine: 5.9 magnum
Default
sounds similar to what happened to me few months ago. Ended up being my fuel pump.
__________________
1999 Ram 1500 QCSB 4x4 360, 3.55 gears, 265s, Shortys with custom exhaust, Spectre intake, Superchip.
More upgrades to come when the money tree out back grows. HS 1.7, ARB or LSD, 285s
Meatball12 is offline   Reply With Quote
Old 12-18-2016, 11:30 PM   #8 (permalink)
Ram Year: 1998
Engine: Magnum 5.9
Default
Well thanks for the info on the ASD relay, when my truck would die it would generally start right back up, only once did it give me a little trouble but that must have been unrelated. Swapping the ASD relay cleared everything up for me.
Old 12-18-2016, 11:45 PM   #9 (permalink)
Jrock2394's Avatar
Ram Year: 1996
Engine: 5.2 V8
Just an update on this. Didn't get a chance to look at it yesterday because of snow so this morning I popped the hood to see what was going on. Upon further inspection, the ignition coil wire turned out to be laying on the manifold melted clean through. Popped the old wire off and put a new one on and it fired up. Guess I got lucky on this one thanks for the input guys appreciate it.
Old 12-19-2016, 12:31 AM   #10 (permalink)
scoose's Avatar
Ram Year: 2007 1500 GONE 2011 1500 SOLD Current --->2016 2500
Engine: 6.7 Cummins
Send a message via Yahoo to scoose
Default
Do we have a prize for Dapepper??
__________________
scoose is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
4 Lo randomly engaging while driving! Withey101 General Discussions 1 07-27-2016 08:56 AM
Anyone Else Randomly Get Insulting Offers for Their Truck? RAMblin1217 General Discussions 32 03-16-2016 04:16 PM
Truck dings randomly Griff923 Audio & Electronics 5 09-23-2014 02:52 PM
truck jerks randomly 1983BETTY Engine & Performance 0 03-16-2014 01:09 PM
truck randomly dies driveljay Tech Info 2 11-02-2012 02:13 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
