Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
TV cable too tight?
This is a discussion on TV cable too tight? within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
So I've been chasing this problem down for a while now and I think k I may have found it ...
Reply
Old 05-19-2017, 10:45 AM   #1 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default TV cable too tight?
So I've been chasing this problem down for a while now and I think k I may have found it but a second opinion would be nice.
When I got this truck there was about half throttle play in the throttle cable. I fixed it and in the process seemed to over tighten the TV cable because a full throttle the truck wouldn't shift and would bounce off the Rev limiter at 80 I stead of shifting at 75 like it does now. Well I've also noticed that at 60-75mph the Torque converter will lock/unlock. It doesn't do it before 60 or after 75. So I can cruise smoothly at 80mph. I've replaced and even checked the new TPS which is smooth in voltage.
Another issue I have is when driving it will shift hard and lurch forward when going into the next gear. More noticeably into OD while getting on the highway.
So at this point I'm wondering if all this isn't just the TV cable being too tight still. I haven't adjusted it yet but after adjusting the play in the throttle cable I'm thinking that the TV cable needs readjusting.
Edit: Whoops, completely forgot. It's a 1996 Dodge Ram 1500 5.2L with about 119,500 miles on it.
Sent from my Nexus 6 using Tapatalk
Sponsored Ad
Register to remove this ad.
__________________
Plenum Plate fix with Fel-pro gaskets
NGK V-Power plugs
MSD 8mm Wires
MSD Blaster Coil 8228
Accel Cap and Rotor
After Market Tow Mirrors (Don't care for the flip up but I'm happy they don't try to show me my own reflection)
Shadow_Death is offline   Reply With Quote
Old 05-19-2017, 12:28 PM   #2 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
Ok so I did some digging and I found the proper procedure to the throttle valve cable. It seems it is too tight BUT it also seems that I can't adjust mine?
So I figured it out. My truck is a 96, seems that cable is for a 95. I've adjusted it. Will report back later.
__________________
NGK V-Power plugs
MSD 8mm Wires
Accel Cap and Rotor
Old 05-20-2017, 02:19 PM   #3 (permalink)
Ram Year: 1996 indy pace truck
Engine: 5.9
Default
How did you adjust it in the first place, cause I have the same problem.
goodtodoo is offline   Reply With Quote
Old 05-20-2017, 10:17 PM   #4 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
https://www.youtube.com/watch?v=DoyCJaGaUoY
Hopefully that is clear enough. I shot that a few hours ago and that Texas sun was setting in the background so it washed out the video quite a bit.
Short answer is the square with 3 arrows on the side is actually a button that you can press and it will allow you to adjust the cable as needed.
__________________
NGK V-Power plugs
MSD 8mm Wires
Accel Cap and Rotor
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Anyone know of any tight to body side steps? bobbobobbo Exterior 3 03-16-2016 02:02 AM
Once it's loose, can it ever be tight again? KahneFan Interior 29 10-10-2015 06:32 PM
steering tight the codes Tech Info 12 11-12-2014 11:14 AM
will or is my pinion nut tight enough???? nigthrunner General Discussions 11 10-08-2014 08:40 AM
A tight fit audio1der Member Trucks 30 08-10-2012 03:06 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
