Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
U-joint popping
This is a discussion on U-joint popping within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
has anyone replaced the u-joint on their truck? my right front wheel pops and is in need of replacing. was ...
Reply
Old 02-21-2014, 01:22 PM   #1 (permalink)
Ram Year: 1997
Engine: 318 5.2
Default U-joint popping
has anyone replaced the u-joint on their truck? my right front wheel pops and is in need of replacing. was just wondering how extensive this will be.
Sponsored Ad
Register to remove this ad.
97CAMORAM is offline   Reply With Quote
Old 02-21-2014, 02:44 PM   #2 (permalink)
Ram Year: truck
Engine: gas
Default
Yes lot's lol. You are looking at about 1-2 hrs work per side. Sometimes the hub/unit bearing can be a PITA to get out of the knuckle the rest is not to bad. It is in the factory service manual if you have it. You can leave the axle nut and shaft on/in the unit bearing and change the u-joint that way, but a bit harder to change out the u-joint.
Merc225hp is offline   Reply With Quote
Old 02-21-2014, 03:41 PM   #3 (permalink)
Ram Year: 1997
Engine: 318 5.2
Default
I've already replaced both hub assemblies, should've done the u-joints then but was on a budget lol but that's cool I can deal with that. any special tools required?
Old 02-21-2014, 07:06 PM   #4 (permalink)
Ram Year: truck
Engine: gas
Default
Nope but if you have a u-joint/ball-joint tool thats makes the job a bit simpler. Be nice when you put those shafts back in don't need to be replacing seals, also it might leak a little gear oil into the tube when the axle shaft is out so it might drip for a day or two. On occasion the collar in the cad will fall forward, so keep that in mind if the pass side axle shaft does not seat all the way in.
Old 02-21-2014, 09:54 PM   #5 (permalink)
Ram Year: 1997
Engine: 318 5.2
Default
Ok sweet, i'll tackle this tomorrow morning and see how it goes. I've watched a few videos as well and it doesn't seem to be too bad. Thanks for the info Merc, I'll update and let ya know how it went.
Old 02-22-2014, 08:17 PM   #6 (permalink)
Ram Year: 1997
Engine: 318 5.2
Default
Just updating. swap went smooth. ratchet,socket, and hammer used; whole job took about an hour.
Reply
Tags
97 ram u-joint, u joint popping
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Popping out of 4wd StarfishFarms Exterior 0 02-04-2014 04:39 PM
Popping/clunking from steering box fla crkr 1 ton General Discussion 2 01-07-2014 07:25 PM
Grinding and Popping noise 98liftedcamo General Discussion 3 01-01-2014 02:16 PM
Grinding & Popping Noise 98liftedcamo Tech Info 0 03-27-2013 09:04 AM
Name this POPPING noise.. huntram03 General Discussions 5 10-02-2012 10:20 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
