98rumblebee
Has anyone ever put a 5.9 magnum in the place of a V10? Wondering if motor mounts line up or if mounts from 5.9 can be bolted in place of the other mounts, etc. Also if the PCM (if that's the proper term for these) can be swapped in and everything will work. Truck is a 95 2500 and the 5.9 would be from a 98. Both automatics, could the transmission behind the V10 be retained or would I have to use the 46re from the 5.9? Not sure if OBDI to OBDII would be an issue, etc.
I realize it's a lot of questions, just wondering if anyone has any info. Reason I'm asking is because I have a perfectly good 360 and 46re in my 98, but the truck is half rot and the front axle is bad. And I found the 95 2500 4x4 for sale with a bad 8.0L V10 for a very good price, the truck is in great condition other than the bad engine. Thank you for any help.
