Wiring gauges!!! HELP
01DodgeRamMan
Wisconsin
lol im hooking up an oil temp gauge, vacuum gauge and a trans gauge, any help on installing these duh to the "glowshift" not giving specifics lol
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
What exactly do you need help with on it? need a little more specifics? Theres so many things you could do.
BlackedOutHemi
DFW, Texas
2012 & 2012
I would think the vacuum sensor is going to have to be spliced into the vacuum lines with a tee fitting somehow.
Oil temp is gonna take some thinking, do you have a stock oil pressure gauge?
01DodgeRamMan
01DodgeRamMan
Wisconsin
Yes sir and I've heard about t fittig that. I've heard getting a oil filter sandwich thingy lol
BlackedOutHemi
DFW, Texas
2012 & 2012
Okay. So, on the oil temperature, basically, pull out the stock sensor, find a tee fitting that goes into that sensors spot, and then put the oil temp on one side and the stock pressure fitting on the other. I realize we have different trucks. But thats how my oil pressure gauge is hooked up.
