Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
wobbling in the front
This is a discussion on wobbling in the front within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
I was wondering if anybody could help me with this problem when driving down the road my front end bounces ...
Reply
Old 11-29-2016, 03:05 PM   #1 (permalink)
Ram Year: 1997
Engine: magnum 5.2
Default wobbling in the front
I was wondering if anybody could help me with this problem when driving down the road my front end bounces when I go to press on the brakes and come to a stop it begins to bounce even worse any help is appreciated
Sponsored Ad
Register to remove this ad.
tfloyd is offline   Reply With Quote
Old 11-30-2016, 12:02 AM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Bounces worse when stopped? Generally means misfire or something like a motor mount is severely degraded
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 11-30-2016, 01:06 AM   #3 (permalink)
Ram Year: 2001 ram 3500
Engine: V10
Default
are the tires in good shape? I had a car that had dynamite radials, but they had set for some time nearly flat. When I aired them up, and drove it for awhile the belts broke and the tires got all misshapen, so they'd wobble. It was odd, because they looked ok, and sometimes rode ok, but when the lumps were opposite each other , I assume, the car would ride like a clown car.
Rustycowl69 is offline   Reply With Quote
Old 11-30-2016, 01:08 AM   #4 (permalink)
Engine: V10
Default
could it be warped rotors, or bad hub bearings, or both?
Old 12-01-2016, 01:26 PM   #5 (permalink)
Ram Year: 1997
Engine: magnum 5.2
Default
I just put a new motor in it 2 weeks ago so I know it's not the motor mounts and I also just changed the drive side wheel hub the passenger side is still good and if checked my rotors there also good and my tires are still in good shape. and it bounces when I start applying the brakes but it doesn't do it all the time.
Old 12-01-2016, 03:16 PM   #6 (permalink)
Engine: V10
Default
the tires may be hard to spot by yourself. Have someone drive your vehicle, and follow in another. Watch the sidewalls, inside and out. It's easier to see rear tire problems by following from behind. If it is the fronts, you might have to walk alongside, or in front of vehicle to see if the sidewalls or tread are running out.
what about the shocks? maybe they're making a marginal situation worse.
Old 12-05-2016, 06:58 AM   #7 (permalink)
montrese04's Avatar
Ram Year: 1999 single cab 4x4
Engine: 5.9L
Default
Believe that something with your brakes and rotors might perhaps not be aligned correctly I've had this happened to me twice before but on a different style vehicle and I had to go back and check and then check and then check again and then I realized that it was my brakes and rotors that were causing the issues because they were not aligned correctly also make sure and check your lug nuts because I I've had that happen due to lug nuts
Sent from my HTC One_M8 using Tapatalk
__________________
Using Tapatalk
montrese04 is offline   Reply With Quote
Old 12-05-2016, 12:22 PM   #8 (permalink)
Ram Year: 1998
Engine: Magnum 5.9
Default
Sounds like warped rotors to me. do a search on youtube and see if videos compare.
Max78 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Will a Rancho front bumper make front components wear faster? Hemipig Exterior 0 09-20-2016 02:56 PM
wobbling RamRT Lowered 20 05-29-2015 02:07 PM
Shaking/Wobbling at 40mph fifteenhundred Engine & Performance 8 12-10-2014 02:18 PM
Front pinion bearing gone. How hard to remove front diff? Caustic Tech Info 2 09-09-2013 07:12 PM
2500 HD Front Bumper Vs 1500 Front Question SafetyGuy General Discussions 7 10-21-2010 12:51 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
