Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Lowered
Lowered
Alignment "issue"
This is a discussion on Alignment "issue" within the Lowered forums, part of the 2nd Gen : 1994 - 2002 category!
Dropped truck 2" up front with coils. Installed new controls up top (SO easy compared to cutting out the ball ...
Reply
Old 06-02-2015, 08:43 AM   #1 (permalink)
DodgeDrew71's Avatar
Ram Year: 2001
Engine: 3.9
Default Alignment "issue"
Installed new controls up top (SO easy compared to cutting out the ball joints.) and cut off and installed new ball joints on bottom. Also installed new hub/bearing assemblies.
Took into Firestone to get their lifetime alignment.
Travels down road like a charm, and feels so much better.
However they couldn't get the camber within spec. Said they were at max.
(Left) -0.4 (Right) -2.0
I can live with the -.4, but man that -2.0 is much different.
I'm going to stick my head under there tonight and give a look myself.
But curious if anyone else has run into anything like this and found a solution.
Thanks
Sponsored Ad
Register to remove this ad.
__________________
-Drew
2001 Ram 1500, 2WD, Std cab, 3.9
2/4 drop from Suspension Specialists
DodgeDrew71 is offline   Reply With Quote
Old 06-15-2015, 10:45 PM   #2 (permalink)
tommyboi87's Avatar
Ram Year: 1999
Engine: 5.2 Magnum
Default
Same problem I'm having maxed out caster and camber. Not really sure what else would help.
Sent from my SAMSUNG-SM-G925A using Tapatalk
__________________
1999 Ram 5.2L Magnum 4/6 drop CAI 4.10 FD Gear Cowl 2" Hood Electric fan Conv.
tommyboi87 is offline   Reply With Quote
Old 06-15-2015, 11:14 PM   #3 (permalink)
HeavyD's Avatar
Ram Year: 2004
Engine: 4.7 SOHC 5 SP Auto
Default
You need to elongate the holes so it can be aligned properly.
__________________
2004 Ram 1500 QC SB 2wd 4.7L - E-fan Conversion, Airaid Intake tube & Filter through Awesome Hood scoop, DJM flip kit 4 3/4" rear. 2 3/4" front. Lots of chrome added. Superchips Vivid. Borla Duals. Lund Tri-fold. 20" Dodge rims. Powertrax No-Slip. Durango R/T front Power Seats. OEM Step Bars. My Thread
HeavyD is offline   Reply With Quote
Old 06-16-2015, 03:41 PM   #4 (permalink)
Ram Year: 2001
Engine: 3.9
Default
I thought the same thing when I took a look the other day.
In a couple weeks I'm installing a new steering box and pump. So will elongate the holes and then take it in for another alignment. (glad I got the lifetime warranty at Firestone.) Should be good to go after that.
Thank you for the response.
__________________
-Drew
Old 06-16-2015, 05:52 PM   #5 (permalink)
HeavyD's Avatar
Ram Year: 2004
Default
is that lifetime warranty when you mod something?
__________________
Old 06-17-2015, 12:34 PM   #6 (permalink)
Ram Year: 2001
Engine: 3.9
Default
Yes, I asked that same question to them. I got the alignment after I installed the lowering coils and they noted it as well. So the initial alignment was when it was already lowered. I asked about when I do work on it and how that works--i.e. the Steering box and tie rods. They said I'm good and to bring it in to have an alignment. (Better for the $200 I paid--versus the $90 if I had just a basic warranted alignment.)
I know the guy's name who I spoke to (Drew just like me) so if anything comes up I'll be pushing the topic. But not too worried, been there twice and they are a good store.
I don't think they'll notice the bit of filing/drilling I will do.
__________________
-Drew
Old 06-17-2015, 05:49 PM   #7 (permalink)
HeavyD's Avatar
Ram Year: 2004
Default
I looked local & they don't do that here - bummer.
__________________
Old 07-07-2015, 11:50 AM   #8 (permalink)
Ram Year: 2001
Engine: 3.9
Default
Well finally got around to getting some things done on the truck this weekend. Took off the upper control arm on the pass side and lengthen the slot for adjustment. Took it into Firestone and now instead of a -2.0 camber I'm down to -1.0 -- guess I need to work on it a little more. :P
they didn't give me any issues and said for all they care I could bring it back tomorrow and have them do it again since I have the lifetime warranty. Definitely worth the $.
__________________
-Drew
Old 07-07-2015, 03:35 PM   #9 (permalink)
tommyboi87's Avatar
Ram Year: 1999
Engine: 5.2 Magnum
Default
So opening the holes helped that much huh? Think you can post a pic of how much you open them all together?
__________________
Old 07-07-2015, 03:53 PM   #10 (permalink)
Ram Year: 2001
Engine: 3.9
Default
Sure, it'll probably be a couple weeks before I get back to it.
But I can tell you I lengthened the slots more than a 1/8" but less than 1/4" (toward to tire) I didn't take a hard measurement with calipers prior, wish I had now, but I didn't want to over do it, so will take a crack at it again and head back to firestone.
I'm going to lengthen it about 1/8" more and see if that will get me to zero camber. But a little negative isn't bad, but -2.0 was too much for a street use truck. (would like to get it between -0.25 to 0.00)
__________________
-Drew
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Im being told a 2" level will give me "death wobble", suggestion? ivan Lifted 20 02-08-2016 05:36 PM
FOR SALE: Kicker 6"x9" and 3.5" speakers & 2 hideaway powered subwoofers DavidRam For Sale 44 11-14-2014 08:31 PM
2" Lift, Alignment? 800steve Lifted 3 08-25-2014 10:51 PM
Thoughts about "truckonator" or the "tornado" intake fans jschreiber94 Engine & Performance 16 08-07-2014 12:58 AM
"Hash marks" or "muscle stripes" rileybrennan Exterior 31 06-21-2013 03:25 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
