i want to lower my front end 4 inches on my 01 but i cant find a kit for 2001 that has springs and spindles it seems like they all skip 2000 and 2001. is there any way to lower the front 4 inches?
For a 4 inch drop, that's usually more than most people. So you might have to piece together a drop. Like spindles and springs. As all the drops I found so far also stop at 2000. What's the difference in year models as far as suspension?
i don't know the differances but i cant even find spindles with out springs.
i was wondering if i could just cut 2 more inches off of 2 inch lowering springs?
what series? i have belltech coils for sale. were on my 3500 dually for 2 months still like new. and yes you need to pop upper ball joint to get the coils out as well as taking out the sway bar links
Its a 1500 I don't think 3500 springs will ride very good on a 1500 might be a little stiff. It dems like a lot of work to keep popping out the spring and cutting a half coil at a time. Wish there was an easier way to do it. Doesn't it mess the ball joint up when your smacking it with a ball joint removal tool?
