Reverse level questions
Mohpar
Texas
Magnum 5.9
What is the largest tire size you can run with no front or rear spacers?
To reverse level, do you simply unbolt the U-bolts holding the rear blocks in, take the blocks out, and tighten the U-bolts over the bare springs riding on the axle? Video or pictures?
dapepper9
Iowa/Nebraska Border
5.9L V8
Reverse level you are correct is removing the rear block. HOWEVER, do not reuse the ubolts. They're tty and you'll need a new set of factory 2wd u bolts. Should still be able to run 33s fine, maybe a little bit of rub
