2.5in Suspension lift question
JSchni
Wisconsin
5.9L
I have a 1999 Dodge Ram Sport 1500 5.9l
I recently bought a 3in body lift and I could not put it on due to rusted bolts on the bed. So I'm not going to cut my bed up for that.
If i get a 2.5in leveling kit what should I get, and what should I do for the rear.
(ex. torsion key, block, add a leaf) I want the lift to be equal in height for the front and rear. Also is there anything else I need for a lift like this.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
You don't have torsion bars at all on this truck.
Do a 2.5 in spacer and an equal add-a-leaf in the back.
You might eventually need an adjustable track bar for the front, as 2.5-3 inches is really pushing it's limits.
heavymetal
Ontario, Canada
5.2, Cam, Headers
my truck has torsion bars? their right next to the muffler bearing....no but seriously..what are your plans or goals for your truck?
im running a 3' inch spacer from hell bent steel, they were 100 shipped to my door. took me around and hour in the driveway alone to put in, i did shocks at the same time, also took off the front swaybar. i did the spacers to level my truck.
you could run a block in the rear aswell. an add a leaf is a better choice though.
post pics!
JSchni
JSchni
Wisconsin
5.9L
would you recoment a 2in coilspring instead of a coilspring spacer
JSchni
JSchni
Wisconsin
5.9L
Im raising my truck to fit my 33's with no rub, on stock they rub a little.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
The coil with a longer shock will ride better, that's for sure. However they ARE more expensive, and slightly more labor intensive depending on the brand. With a spacer you unbolt the shock, lift the frame, and let the axle droop slowly.
And I run 33's with only a little rub. :naughty:
JSchni
JSchni
Wisconsin
5.9L
heres my truck right now with out the lift
picture.php
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I don't see why that wouldn't work. Just remember that your track bar may or may not like the level. lol
fastSdime
Westmoreland, KS
1999 Ram 1500
5.9 Magnum 360
I run 33s on 20s stock height and I only rub when backing up and cranked fully to the right.
Rcr55
San Antonio, Tx
5.9 360 magnum
What kind of shocks do you recommend for a 2.5 inch lift?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Most run stock length shocks. It just makes the ride a bit stiff since they can't extend quite as far.
I'm thinking Bilstein makes a good replacement shock for lifted applications.
