2wd lift help
RamCode
Baltimore, MD
5.2 Magnum
Ok I can't be the only one who is trying to lift their 2wd. When I bought the truck the previous owner put a 3 inch level kit on the front and never changed the shocks. it sits with a funny stance now and rides rough as hell. My question is should I change out that 3 for a 2 inch and add a body lift or just replace the front shocks and add a block to fix the stance?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Merc225hp
NA
truck
gas
People do it just not as many as the 4wd trucks and aftermarket support for lifting a 2wd 2nd gen is slim. To my understanding 2.5 in the front for a 2wd is about it before things go wacky in the front suspension. I think there is a 5.5 lift kit out there for a 2wd 2nd gen bds maybe. Use a add a leaf in the rear over using blocks if you want to level it.
Merc225hp
NA
truck
gas
Ruff ride, hard to align the front wheels, odd behaviour going over bumps in the road, hard to steer, road wandering. A arms, ball-joints, steering all need to be addressed when lifting a truck more so on a 2wd. If there is a spindle lift out there that is the best way to go, otherwise a good kit will have new upper A arms, steering parts, possible new spindles and coil-springs I have also seen them coming with a new crossmember for under the motor.
It all comes down to keeping the geometry right when lifting a truck.
RamCode
RamCode
Baltimore, MD
5.2 Magnum
Ok so I should ditch the level kit all together and put a spindle lift on. Could I fit 35s with this lift?
Tapatalk Time
Merc225hp
NA
truck
gas
To use the truck with 35's you need a good 5" lift, so like your org post small suspension lift and a body lift is how I would go to help keep the cost down, if money is not an object then suspension lift all the way.
RamCode
RamCode
Baltimore, MD
5.2 Magnum
Well money is an issue lol. Do you think the 2 inch level and body lift will let me run 35's?
Tapatalk Time
Merc225hp
NA
truck
gas
So a 2" level and a 3" body is 5" so I don't see why not. In your case its all about the inner fender liner and the dog leg of the fender itself. Both can be modded to a small point without too much hassle.
RamCode
RamCode
Baltimore, MD
5.2 Magnum
I have the 3 inch right now and I'm running 33s with no rubbing. Youve been a ton of help. Thank you so much
Tapatalk Time
Merc225hp
NA
truck
gas
Anytime glad to have been able to offer some light. You know you should be changing your gear ratio to match the 35"s. Depending on many things this could be from 4.10 to 4.56 something to think about as it's not a cheap endeavor, around $600 in parts and labour.
RamCode
RamCode
Baltimore, MD
5.2 Magnum
Yea I know if I go to 35s then I need to regear. Not looking to get new tires till these new 33s wear down.
Tapatalk Time
Happ!
I know this is old but is it possible to get a wide shot of this?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Sounds like he wants a full shot of your truck.
Happ!
Exactly. Thanks you fellas. Looks good. So what was the ultimate outcome? I wanna run 20x9 and I'm trying to see if I'll need a lift in the front to alleviate any possibility of rubbing.
RamCode
RamCode
Baltimore, MD
5.2 Magnum
It is a 3 inch spacer up front. When these tires run bald I'm swapping for a 2inch and going down to 285s
Tapatalk Time
Happ!
What size is the wheel and tire combo your running right now. That stance your sitting at is what I'm looking for mine is stock with the front angled towards the ground.
RamCode
RamCode
Baltimore, MD
5.2 Magnum
Right now I'm running 305s with a 17 inch wheel. I rub at full lock.
Tapatalk Time
