Shouldn't, unless they're worn out.
Theres no point lifting multiple times if thats what you're thinking. Pick a height amd go with that.
5" will require longer springs, longer shocks, drop pitman arm, drop track bar bracket, appropriate control arms and lift leaves or add a leaves for the rear.
No I wasn't going to lift multiple times I was just wondering what I would need if I lifted 5 inches.
Would I need to change brake lines if I lift it 2.5 inches?
I don't need to change gears right? I will need new shocks. And a steering wheel stabilizer? What's that for?
Ohh ok.
No you'll be fine.
As long as you stay with a 33" tire youll be alright. Need to regear for 35's. Plus front end out wears out a lot quicker. Yes you will need new longer shocks designated for that much lift. What do you mean steering wheel stabilizer? Are you talking the stabilizer on the front axle? Thats supposed to help stop bump steer iirc. You dont need one of those for a lift, stock works fine.
Bilsteins are good shocks, so are Monroe's.
You're welcome haha not a problem. You might look into an adjustable track bar as well for the lift but it isnt necasarry. Will help prevent death wobble. Be sure to post pics!
Nice to see another RF member from San Antonio!
