97 ram 1500 4x4 lift advice please
Johnn123
Ontario
Shouldn't, unless they're worn out.
R
Rcr55
San Antonio, Tx
5.9 360 magnum
If I do a 5 inch suspension lift, what are the top things ill new to change on the truck? Ima do a 2.5 inch lift but ill like to know what I would need to change.
Johnn123
Ontario
Theres no point lifting multiple times if thats what you're thinking. Pick a height amd go with that.
5" will require longer springs, longer shocks, drop pitman arm, drop track bar bracket, appropriate control arms and lift leaves or add a leaves for the rear.
R
Rcr55
San Antonio, Tx
5.9 360 magnum
No I wasn't going to lift multiple times I was just wondering what I would need if I lifted 5 inches.
Would I need to change brake lines if I lift it 2.5 inches?
I don't need to change gears right? I will need new shocks. And a steering wheel stabilizer? What's that for?
Johnn123
Ontario
Ohh ok.
No you'll be fine.
As long as you stay with a 33" tire youll be alright. Need to regear for 35's. Plus front end out wears out a lot quicker. Yes you will need new longer shocks designated for that much lift. What do you mean steering wheel stabilizer? Are you talking the stabilizer on the front axle? Thats supposed to help stop bump steer iirc. You dont need one of those for a lift, stock works fine.
R
Rcr55
San Antonio, Tx
5.9 360 magnum
Ohh ok.
No you'll be fine.
What kind of shocks should I get?
R
Rcr55
San Antonio, Tx
5.9 360 magnum
Bilsteins are good shocks, so are Monroe's.
Alright! Thank you so much! You've helped so much! I'm definitely going to buy the 2.5 inch lift kit! I want my truck looking badass like yours lol
Johnn123
Ontario
You're welcome haha not a problem. You might look into an adjustable track bar as well for the lift but it isnt necasarry. Will help prevent death wobble. Be sure to post pics! :D
R
Rcr55
San Antonio, Tx
5.9 360 magnum
Yea I will look into that!
Yea definitely man I will! Now to buy everything!
Johnn123
Ontario
It will definitely make a good difference in your truck after the lift.
Haha I hear ya Im still piecing mine together :D
R
Rcr55
San Antonio, Tx
5.9 360 magnum
what else are you gonna do to it?
yea hopefully man! how much do you think the lift will cost?
Johnn123
Ontario
Ill pm you just so we dont get to far off topic.
FancyStancy
Texas
Cummins 6.7
Nice to see another RF member from San Antonio!
jbmobbs
murfreesboro, tennessee
uploadfromtaptalk1394250076149.jpg my rides. To give u lift ideas the white dodge is a 6" lift on 35s and the black dodge is a 13" lift on 38s.
Sent from my DROID RAZR using Tapatalk
Johnn123
Ontario
^^ Id like to see more of the black one :D Got any pics of the lift set-up?
