Adjustable Track Bar Help/Q's!!
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
From what I have herd it is a smart idea to replace your stock track bar when installing a 2.5" level kit so that you can avoid the death wobble. But while your at is, would it be smarter to purchase an adjustable track bar so you can compensate for the 2.5" lift?
I've done some searching on here and also on the suppliers that offer adjustable track bars but I can't decide as to which one or if I should just get an OE replacement track bar? Maybe OE bar replacement and track bar drop bracket to compensate for the lift?
I apologize for the million questions, but this is the only place I know to turn to when I can't find the answer anywhere else
:love51:
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
Looking for this exact answer. will be tuning in
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I wouldnt buy an adjustable or replacement oem track bar until after you put on the lift and see what happens.
I want to avoid the chance of the death wobble as much as possible so i went ahead and ordered an Acdelco oem track bar for about $51 with the 3/4" tapper so I hope it will fit!
bassslayer25
East, Kansas
5.9 360 V8
Should fit. Should make everything feel better.
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
I've just got a track bar drop bracket on mine with an OE replacement track bar. No death wobble here.
ramburger
u wont get death wabble duder but its still money well spent if you eventually gunna lift it more whch u will
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
I just put the skyjacker adjustable track bar on my truck for the 5" lift. Haven't drove it yet but I can update you if you want.
Merc225hp
NA
truck
gas
There are a couple of upgrades I would do with that sj trackbar I will pm you later.
mitchbowers
Ohio
5.9 Magnum
Can you include me in on that? Ill also be leveling sometime here in the future
