Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Lifted
Lifted
Another 2500 sping swap question
This is a discussion on Another 2500 sping swap question within the Lifted forums, part of the 2nd Gen : 1994 - 2002 category!
Hello all, I have a 2001 1500 2wd quad cab that I use as a farm/work truck. I also use ...
Reply
Old 01-02-2017, 10:17 AM   #1 (permalink)
Ram Year: 2001
Engine: 5.2
Default Another 2500 sping swap question
Hello all,
I have a 2001 1500 2wd quad cab that I use as a farm/work truck. I also use it to tow a 31 foot camper for short distances (75 miles or less) across flat land. I want to improve its towing capabilities a bit as well as give it a little better stance. In the rear I am planning to add a leaf as well as put on a set of monroe coilovers. In the front I plan on installing new shocks and a set of 2500 coil springs, which leads to my question. I am going to order a new set of springs from Moog, so should i order the springs for the v8 or v10 gasser 2500? I wasnt planning on ordering the diesel springs as it is my understanding that they may lift the front end too much. Anybody have suggestions as to which set I should order? It would be great if I could get a couple of inches of lift in front without having to do any major mods other than popping in new springs and shocks. Thanks!
Sponsored Ad
Register to remove this ad.
csuthrower04 is offline   Reply With Quote
Old 01-03-2017, 12:39 PM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
V8 springs won't be any stiffer than what you have now, v10 and dsl springs are the same
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 01-03-2017, 03:31 PM   #3 (permalink)
Ram Year: 2001
Engine: 5.9 magnum
Default
So the 2500 front springs are the exact same ones in the 1500?
__________________
2001 Dodge Ram Sport RCSB 4x4 5.9 3.55gr
MODS: bbk tb, bosch 24# 4hole inj., hs1.7rrs, 3842superchips, cloyes dbl roller, blackmagic elec fan, volant/spectre cai, 3"hiflo cat, 3"magnaflow, accell coil, taylor 8.2 wires, borgeson steering gear&shaft, rs steeringbushing, modded kegger
mda8569 is offline   Reply With Quote
Old 01-04-2017, 08:38 PM   #4 (permalink)
Ram Year: 2001
Engine: 5.2
Default
Thanks yall. Moog makes a replacement spring for the v10/ diesel 2500. I think I'm gonna purchase a pair of these and some new shocks instead of jer king a pair out of junkyard that's 20 years old. Do yall reckon my stock control arms can handle it?
Old 01-04-2017, 10:06 PM   #5 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
You should be good to swap in the 2500 springs from a V-10 or diesel. There is no difference as far as i'm aware between the 1500 and 2500 mounting wise. Your front end will sit a bit higher, how high i'm not sure, mine has had the diesel set on it since I bought it.
An add a leaf in back will raise it by less than an inch unless the back is really tired. Then it could lift it by 1in or more, but not for very long.
The best bang for your buck would be to goto a place like rockauto or Husky and get some 5 leaf spring packs. That way you are good for your short trips, but if you do want to load it down or go for a longer trip, you won't have to worry about snapping one of the old leafs on the road.
I paid about $350 for the pair, including shipping on a set of Husky springs.
Thats what happened to me at least. I hit a pothole a couple hours from home with a flatbed trailer and small tractor. The rear eye snapped and the spring slammed into my bed, i'm lucky it didn't bust a hole it in.
Now, my back end sits about a 3/4in higher in back, and there is no sway from my travel trailer. Before, I could see the axle shifting slightly when the wind would hit the trailer going down the highway.
Just an FYI to replace the rear springs, you need to drop the tank, or at least loosen it to get access to the front mounting bolt.
Old 01-05-2017, 10:27 AM   #6 (permalink)
BBartow's Avatar
Ram Year: 1995
Engine: 5.9L Magnum
Default
I'm not sure how much v10/dsl springs will lift it on the 2wds but if its over 2.5" you will need new upper control arms.
__________________
BBartow is offline   Reply With Quote
Old 01-08-2017, 10:42 PM   #7 (permalink)
Ram Year: 2001
Engine: 5.2
Default
Thanks for the input yall. Dudeman2009 I am gonna take your advice and get a 5 pack of leaf springs for the rear. Did you buy the Husky's off or rockauto? Also is your 1500 a 2wd?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cluster swap in 6.4L 2500 Mopar_Magic_Man Interior 6 07-31-2016 10:22 PM
New rear coil sping 2500 rides like crap 20162500 Heavy Duty 62 03-14-2016 03:12 PM
2500 leafs swap? C.Carmichael Towing & Hauling 6 01-24-2014 02:23 PM
2500 parts swap ? Whitehemi Exterior 1 01-13-2013 08:32 AM
2500 gas to diesel swap? Muddinginamopar General Discussions 23 09-07-2012 11:35 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
