ProjectSlim
So i lifted my truck with a coil spacer on top of a spindle lift in order to level it out now my ball joint are going out because being at such a bad angle. Has anyone had this problem? If so please help.
Id look at some Zones Upper Control arms. They are made for Lifted Trucks to not put the stress on the ball Joints. This is why they say to replace them if your going over 2.8 inches with something else so you don't have this issue. Id check out the Zones but there are other manufactures that make them also.
