Hey Guys, I'm new here to RF and have a few questions you guys may be able to help me with. I have a 2001 Dodge Ram 1500 Sport Off-Road edition with a 5" Rough Country Suspension lift on 35's. I also have bushwhacker fender flares and unfortunately my tires rub slightly when cutting the wheel real hard. I would like to raise the truck a little bit to run bigger tires (maybe 38-40") and was looking for suggestions. Skyjacker has a 4" Add-a-leaf kit which sparked my interest. My questions about that are, because I have the 5" lift blocks in the back and the U-Bolts that came with the suspension kit, will that leave enough room for the add-a-leaf or would I have to buy new U-Bolts? Second if I don't need new U-Bolts would I have to get longer brake lines, or longer e-brake, etc? In the front I've been looking for a 4" coil spacer to match the 4" in the back. I've found a couple but my questions with that is, do I then have to adjust anything else? (Sway bar, tie rods, etc?) Or am I totally over thinking this and it is actually as simple as using the U-Bolts that came with the suspension kit as well as just mounting up the spacers in the front? Any info would be helpful. I am not set on it being 4" spacers. If 3" is much easier and can get away with having less parts, then I will do that. Any other suggestions would be great.
Thanks!
Thanks!
