Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Lifted
Lifted
Control arms on 13in lifted ram
This is a discussion on Control arms on 13in lifted ram within the Lifted forums, part of the 2nd Gen : 1994 - 2002 category!
Alright I'm new to this site, an new to the big lifted truck world so to speak. All my other ...
Like Tree1Likes
  • 1 Post By Bigblue07
Reply
Old 11-15-2016, 11:07 AM   #1 (permalink)
Bigblue07's Avatar
Ram Year: 2000
Engine: 5.9
Default Control arms on 13in lifted ram
Alright I'm new to this site, an new to the big lifted truck world so to speak. All my other truck had your typical 3 or 6in name brand lift on them. An luckily there was never any issues with any of the lift or suspension parts while in my ownership.
However, I just recently purchased a 2000 dodge ram 1500, lifted 10in in suspension an 3in body with 44x18.5x15 tires on it. Truck only has 60k miles on it. Zero rust! An has never seen mud or snow! It was a company's show truck they used as a rolling bilboard for their company. It has the 5.9L 360. One hell of a truck!!!
Apon buying this truck I was told by the previous owner that it needed a wheel bearing. Witch is why it wobbled really bad. Almost as if the front wheel was gonna fall off so it felt. Or like there was a belt broke in one of the tires. Needless to say it was the scariest experience ever driving it home. Once I got it home, I immediately went to the parts store an bought a moog wheel bearing. Took 2 nights, 2, 5ton jaw pullers an a 10lb sledge hammer to get the old one out, but I got it out. New one installed an yet, the same problem.
After using a go pro mounted under the truck, I was able to see what was moving under there that was causing the bad wobble while driving. Control arm bushing. Passenger side was gone. You can grab the passenger front wheel while it's parked an see the movment an play in the control arms.
So my question is, how can you tell what kind of brand the control arms are so I can order some new bushings?
After googling a shit ton of pictures I'm pretty confident that it's a tuff country lift. But from what I've found online tuff country don't make a 10in lift. (Reason I say 10in lift is Bc there is 10ins of blocks in the rear)
But, the dual steering stabilizer is bds.
All the shocks on the truck is pro comp.
So I'm kinda clueless to what kind of lift kit this damn truck even has.....please someone she'd some light
Sponsored Ad
Register to remove this ad.
Bigblue07 is offline   Reply With Quote
Old 11-15-2016, 11:24 AM   #2 (permalink)
Csanders1992's Avatar
Ram Year: ....
Engine: ....
Default
I don't have the answer to your question, but damn 10" blocks? That's insane and probably unsafe. I'd go through your entire suspension and do it all right
Csanders1992 is offline   Reply With Quote
Old 11-15-2016, 12:47 PM   #3 (permalink)
Bigblue07's Avatar
Ram Year: 2000
Engine: 5.9
Default
Really? I've seen some guys run even bigger blocks.....there's 3 separate blocks. If I remember right there's a 2, 4in blocks. An like a 1 3\4in block. U bolts still look new so I didn't think nothing of it. Blocks are nice an straight.....yes I have heard it's not good to have that many blocks..due to that being alot of extra weight on the axle housing....I'm still learning this site. I wish I knew how to post pictures
Old 11-15-2016, 12:51 PM   #4 (permalink)
Ram Year: ....
Engine: ....
Default
More than one block is just as bad honestly. And it has nothing to do with weight. The taller the block the worse the axle wrap. If your curious what that can do look up YouTube videos
Old 11-15-2016, 12:57 PM   #5 (permalink)
Bigblue07's Avatar
Ram Year: 2000
Engine: 5.9
Default
[QUOTE=Csanders1992;1398967]More than one block is just as bad honestly. And it has nothing to do with weight. The taller the block the worse the axle wrap. If your curious what that can do look up YouTube videos
So after checking out some vids of what axle wrap is....I kinda doubt my truck would be doing anything like that...only Bc I have these long ass I'm assuming their called control arms that run from the frame down to the bottom of the rear axle.
Old 11-15-2016, 01:00 PM   #6 (permalink)
Bigblue07's Avatar
Ram Year: 2000
Engine: 5.9
Default
Best pic I have of the ass lol
Old 11-15-2016, 01:16 PM   #7 (permalink)
Bigblue07's Avatar
Ram Year: 2000
Engine: 5.9
Default
Pics of the bad control arms/bushings
Old 11-15-2016, 01:18 PM   #8 (permalink)
Bigblue07's Avatar
Ram Year: 2000
Engine: 5.9
Default
More pics
Joe w. likes this.
Old 11-16-2016, 11:56 AM   #9 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
I'd start with those bushings you mentioned. I would imagine they're either tough country like you mentioned or Fabtech. Only other companies that make any for us are bds and dodgeoffroad and those aren't them lol.
If the wobble persists i would probably do a tire rotation. Left on right and right on left. See if the problem follows
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 11-16-2016, 12:27 PM   #10 (permalink)
Divinggumby's Avatar
Ram Year: 2017
Engine: Hemi 5.7
Default
I believe that's a long arm and not a control arm.
Long-Arm Vs. Short-Arm Suspension - 4-Wheel & Off-Road
You may need something custom made to replace what you have since I doubt many people will have parts for a 2000 with a 10" lift. Rubber/ poly bushings are cheaper, FK stainless bearings are fail proof but will make noise.
__________________
2017 Ram rebel 5.7 Hemi. Fully loaded, tinted windows, SRQ back up lights, RB10 running boards, more to come
Past 97 F250 LD 5.4L, 2003 F150 5.4L lifted and modded pretty good, 2013 F150 3.5EB predator- modded pretty good.
Divinggumby is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control arms hotkarl General Discussions 8 04-29-2015 05:46 PM
Control arms ralaubach Lifted 1 12-11-2014 11:27 AM
Control arms Terrance General Discussions 4 06-09-2014 09:20 PM
Need new control arms Wolfhound General Discussions 11 04-18-2014 05:11 PM
Lifted 2500's: Control Arms or Drop Brackets? Hemi5speed Lifted 12 04-18-2014 11:08 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
