"custom" lift?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
a jack, jack stands, socket set, and wrenches. But air tools help too.
the codes
the codes
Houston, Tx
Magnum 5.2
have all that, could get the air tools but need a bigger compressor/tank lol one I have is to small to run the tools. I just worry I might do something to put myself in danger when going down the road haha
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Just make sure its all torqued correctly, and then after a bit of driving go back and check them. I went to harbor freight and picked up a torque wrench on sale pretty cheap
the codes
the codes
Houston, Tx
Magnum 5.2
good advice, and Ill look into getting those air tools over time so when install gets here Ill have em all
Stangshcky12
Oshkosh, WI
5.9 Cummins
My brother put a lift on my brothers cherokee without air tools even (same suspension setup) in about 4 hours. The hardest thing was getting the year shocks off cause they rust to the uni-body and that shouldnt be aproblem with your ram
the codes
the codes
Houston, Tx
Magnum 5.2
I replaced my own shocks so I dont think its out of my ability. As far as installing goes do yall think a Body or Suspension would be easier? does a suspension have a better ride than body?
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Good question. Body lift keeps the factory ride. Probably would be better than a 3 inch lift ride wise. :birgits_tiredcoffee
the codes
the codes
Houston, Tx
Magnum 5.2
makes sense. so on a body lift, how would you go about installing that? I know you have to jack the bed up and install the spacers b/w the frame, how do you lift the cab up? also how do you get the bumpers adjusted?
amdwilsns01
