Dual steering stabilizers... Worth it?
98_laramie_318
Cape Cod
318 Magnum
Anyone here running a skyjacker dual stabilizer setup or similar? I'm running 3-4" of lift and 33x12.5's, I have a little bump steer but it's not bad, I know my tie rods are good and I have a new track bar in the front, I just want to try and correct the general dodge steering numbness a little bit and my stabilizer looks to be original, didn't know if it's worth it or not to go to a dual setup. Any input is appreciated, thanks!
Johnn123
Ontario
Dual stabilizers look cool. Thats about all they do though.
If you want to help your steering look into an adjustable trackbar and a new steering box by borgeson or redhead. Not a reman unit. You can look into the rock solid ram steering fix as well, its a small bushing that goes over the bottom of the steering column.
VLG6963
