Lethalweapon100
Hey everyone. I bring you a stupid question that i am purely curious about, i don't intend to do this. It kinda sounds dumb.
Anyway, RC has a 2" lift. It has an add-a-leaf plus coil spacers in the front to maintain a stock lean (2.5" lower in front) while being 2" higher than stock. What if someone wanted to install that but level it too? Could you put two 2.5" coil spacers on top of eachother and install it? Would you need a 5" extended shock on each side? How dumb does this sound?
Also, if you wanted to just level your truck, just coil spacers, do you need 2.5" extended shock? Does the shock even get any taller when a leveling kit is installed?
Thanks guys!
Thanks guys!
