Magnum5.9
- Aug 8, 2014
- 541
- 66
- 01 ram 1500 4x4
- Magnum 5.9
So finally decided to go forward with the RC 2.5" leveling kit and new variable rate stock coils from rockauto to lift it roughly 3" from where it sits now(because I am thinking the 14 yr old coils have sag a bit over the years). I am also putting on a drop bracket for my sway bar that is designed for 2.5" lift.
My question for you guys is what would you guys to do your other suspension components (track bar, pitman arm, etc) with this setup?
I've read alot that have said your fine just put the lift on and I have also read a few thay were suggesting even doing the control arms, track bar, pitman, sway bar.
I have a buddy at a 4x4 shop that said he can fab up a track bar bracket and that there is enough adjustment in the tierods that we can adjust it the same amount as the track bar drop bracket. I think this would elminate the chance of death wobble?
Thank again guys, you have all been an enormous help!
