vettedoc
- Sep 15, 2015
- 2
- 0
- 2002 2500
- 5.9 gas
Hello Everyone.I have a 2002 2500.As you know for the 2002 model year dodge did away with the front axle disconnect and the front driveshaft turns all the time. Anyhow when I first got the truck the u-joints were bad in the front driveshaft so it vibrated on the hwy bad. I had the u-joint done and the driveshaft balanced. I reinstalled it and it was way better but not smooth as glass.I chalked it up to that the driveshaft turned all the time. Last week I leveled the front 2 inches. On the test drive I noticed the vibration was back at around 60-70 mph.I took the shaft back out and drove it and it was back to normal. The lift kit was only spacers since it was only 2inches(no arms)and it has a double u-joint at the transfer case side so I figure it should be canceling any angle issues out. If anyone has any Ideas I would love to hear from you.I cant help but wonder if it has anything to do with that shaft turning all the time.
