i want to get high, sooo high. lol
'01 Ram
no really, i do. lifted high that is. lol i already have a RC 5" lift on my truck and was looking for at least 3" more. i know i can add a 3" bl to my truck but i was actually looking to add 3" of suspension. what do you folks recommend? i also have stacked blocks out back which i'm very much against so give me some pointers. this stuff is very addicting. lol
TheMaddog
DFW
All truck stuff is addicting. 1st you're in the market for a new radio and boom your truck gets modded like no other
rambob
LA/MS
318 5.2l
I've looked into it. I think a body lift is the way to go. when you start adding spacers on the coils, the suspension geometry changes. unless you have adjustable control arms, the axle will move back in the wheel wells. the effect on CA travel will make the ride more harsh.
I have stacked blocks also. a lift adda leaf plus a block is cheaper, and prob safer, than one big block. plus I think I actually have an issue with the leafs now - torque wrap. so adding a leaf is a good idea for that. of a complete lifted leaf pack. which is $300+
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
go big or go home
this has no body lift
I have looked into the body lift too, but then my tires would be really small
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Body lift...even though reccomended with a suspension lift is the way most people do it.
To do an 8 inch or over lift and make it work safely needs a bit more work. SUL7's truck above is a good example. It's got a lot of fab work.
A properly done 8 inch suspension lft will need longer control arms, front springs, new rear spring packs and/or shackle flip, maybe a t-case clock, Your 1500 axles will hate the larger tires you run, especially if you off road, and you will need a better track bar and steering setup. Oh, and much lower gears.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Looking for at least 3 more inchs for you truck or you lol
ramhunter9
P-Star Jeep Wrangler
Just scrap the lift you have now and get a bigger one . Pics of your truck as it sits now ?
V
'01 Ram
very true. does it ever stop? lol
a body lift it is then, thanks. i kind of figured that this was what you guys would recommend.
go big or go home
i was thinking about possibly going with the 8" suspension lift that TGC offers for our trucks but i just can't see myself spending all that money including install for the kit. at least not at this moment. but wermbang, you can still go higher and this would sort of force you into going bigger on your tires when they wear out.
thanks for the input. this is what i needed to be told.
3" for my truck. you're silly, but i wouldn't mind having 3" elsewhere.:naughty: i'm talking about height just in case. just imagine being 8'11" tall.
does anybody make a 8" suspension lift for a not so expensive price? here is a picture of my truck as it stands. i want to go 8" so that i can rock some 38" tires.
If you decide to do that and everything is in good condition let me know if you'd like to sell it!!!!!
i'll let you know if i decide to sell it. so you know, i take care of all of my things.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
If I go any higher I don't think I will fit in my parking garage at work. Now if the right deal came around, then I might consider it.
Also that blue truck is 14" all suspension
1Popeye
