wingnut
I have a 97 Ram, 1500, 4x4, ext-cab, short-bed. I would like it to sit like the "Off-Road" version of these trucks. About a 2" lift? Would like to do it in a sensible manner. What parts would I need? Thank you.
http://www.ramforum.com/f58/lift_basics_2nd_gen_4x4_rams-25153/
If you want an "off road lift" and the wierd rake of an off road, buy a set of off road springs.
I'd guess a 2 inch front spring and a 3 inch AAL would give you the same effect.
Don't waste your money on V-10 springs, and a 3/4 ton block if off a heavy duty is setup for 3 inch wide leaf springs. Your 1500 springs are 2.5 inches wide.
The offroad editions use the same block. They have an aal installed. Front spring are the same just stiffer as mentioned. I bought an offroad edition as a parts truck. Its blocks were the same as my 99 sport non offroad. It did have an extra leaf in the leaf pack that gave it more lift.
Offroad springs, as I posted before, are not lift springs. They simply have a higher compression rate and can handle more weight, which gives the "lift" in the front. Why the hate on the rake? It has a function, its so your nose isn't skyrocketing when loaded down.... V10 springs would give just as much lift, if not more and would be much easier to find. Yes you can use 3/4 ton blocks.... Thats what the offroad editions use! Its just a 3" block.
Don't try and cheat the engineers! Buy the proper springs and suspension components and do it right.
Obviously you've never worked with off roads...I've lifted a couple or so in my time. Oh and I have cast off off road springs on my truck WITH the factory rear block my truck came with. BTW I don't consider myself the expert on off roads, but I've done a fair bit of research over the last 13 years to debunk the myths.
I don't hate the rake...but I'm entitlled to my opinion. It looks over lifted in the back. I degress.
Here's WHY you don't want to use v-10 or cummns springs in a 1500. These springs were designed for trucks with heavier engines. As you stated...off road springs are higher compression devices. So are v-10 and cummins springs. Therein lies the issue.
Springs also have to have a bit of preload or "pre compression" built in when the truck is at curb weight. Otherwise they would not work properly. Putting such springs in a V-8 1500 doesn't allow them to compress properly and can make the ride skittish and dangerous on certain surfaces, because they in an almost unloaded condition. Even off road springs compress as the truck is lowered onto the tires.
Not to debate a point but the iron block v-10 for trucks is about 816-836 using hughes chart. If that's the case I'd guess you wouldn't get much lift off a V-10 spring and even less if they only weighed about 650. I've never seen V-10 springs recommended...cummins springs yes.
I'm glad you have an off road. It's the best 1500 Dodge has built. It suprised me that you would think the factory blocks are different. That's what threw me. HD 2500's would use 3 inch wide spring.
Don't worry about them.Hi. O.P here. I'm afraid to ask if you guys have settled this yet? I don't do much O-R in the truck, but I like the stance. I'd like to accomplish it with factory components, a well-tested aftermarket product, or a combination.
Some might disagree with me, but that's the cheapest way to get the stance.There is so much weird crap circulating about ORE trucks....
Just do a 2.5 in lift in the front with a 2.5 or 3 in add-a-leaf in the rear. BOOM. The perfect stance for these trucks.
So just to stir the pot up. I just got my dodge for a work truck out here on the pipeline and it gets pretty rough out here so trying to beef it up a little. So the jury is out on if using Cummins springs are a good idea. Me personally I was thinking about em as I have plans to put a heavy duty front bumper and figured that would help holding the extra weight. What do y'all think?
